584,826 active members*
5,275 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > New laser machine Cracking sound, found the problem I think - need advice
Results 1 to 2 of 2
    Jul 2014
    3
    Hi Guys,
    I have a new laser machine from China (150w OLT1390) and have been using it over the past month or 2. Everything has been working fine except I heard some craking/sparking noises coming from the machine when I was engraving at 20% power. I had heard this once before a while ago but then it dident happen again.
    This time it dident stop and then the laser stopped engraving. I stopped the machine to investigate and think I have found the cause. I think it is the High Voltage connector on the laser cable going from the PSU to the Laser. there was a smaller cable sitting underneath the connector which has charred and when i opened tht connector I could clearly see burn marks.
    I have attached some photos.
    Attachment 247822
    Attachment 247824
    Attachment 247826
    Attachment 247828
    I have contacted the manufacturer , but in the meantime what do you guys think, is my laser tube likely to have been damaged also?
    Also is there a good source in the UK I could get a better quality Single Core, High Voltage connector to replace the current one?
    Thanks,
    Sep 2012
    212
    Re: New laser machine Cracking sound, found the problem I think - need advice
    Hi, To confirm whether your tube has been damaged, please have a reference of this video.
    Laser tube problem or Laser powersupply problem - YouTube
    Just ask your supplier to replace the parts to you. It should be covered within aftersales service.
    G.Weike Laser
    [email protected] [email protected] skype:melody.gweike
  1. Need advice on power needed for CNC Laser machine
    By branded in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-21-2014, 02:16 PM
  2. Completely new to this! Need Advice on a New Laser Machine!
    By NGdriver in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-28-2013, 01:55 PM
  3. Looking for advice to buy Laser Engraving Machine
    By Tom Said in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-01-2013, 05:10 AM
  4. Looking for advice on 100w + laser machine purchase.
    By Robot Dude in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-20-2011, 10:17 PM
