I'm making guitars ( solid bodies ) and I want to have the same bit .375 cut the contour for binding.
I can't seem to do a negative contour offset, so how do I do this MC X5? height is .23 thickness is .059
After I cut all my pockets, drill all my holes, cut the contour at finished depth....I want to then take a minor contour cut to finish the body for the single binding.
I tried to do an Xform Offset, but you can't do a negative number.....
This is bugging me greatly.
Then the next thing is setting up the drawing to cut the Arm relief on Strats and the Belly or Contour relief on the back side! That's another question if you can help.
Rob
