585,973 active members*
4,100 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > NEED THREAD MILL PROGRAM FOR C-AXIS
Results 1 to 11 of 11
    Feb 2007
    107
    I NEED A THREAD MILL PROGRAM TO THREAD A 1/4 -18 FEMALE THREAD IN 316 SST. YES I KNOW I CAN SINGLE POINT BUT TOOL LIFE IS TERRIBLE I WANT TO USE MY Z AXIS LIVE TOOLING AND THE C-AXIS.
    THANKS
    BAD DOG
    DAEWOO 240 MSB
    Jan 2006
    4396
    I am assuming that your Thread Milling on the Face of a Part.
    Is this a Fanuc Control, if so which series?
    Also i am assuming that you want to use a Hob End Mill, What Diameter??
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Feb 2007
    107
    THREAD MILL
    YES---FEMALE THREAD, FROM FACE,,,,, .292 CUTTER DIAM.,,,,, FANUC 18 i CONTROL
    WE MACHINE A LOT OF 316 SST,,,, WE USUALLY 2ND OP THESE IN THE VMC BUT I NEED TO HAVE THEM COME OFF THE MACHINE COMPLETE.
    THANKS,
    BAD DOG
    Jan 2006
    4396
    Do you have a Full Y Axis instead of using the C Axis??
    If so, how much travel do you have?
    Toby D.
    Schwarzwald
    Feb 2007
    107
    THREAD MILLING
    NO Y-AXIS THAT IS WHY I WANT TO TRY USING C AND LIVE Z AXIS TOOLING
    BAD DOG
    Jan 2006
    4396
    Does your C-Axis Program in Degrees or an Inverted Scale??
    Toby D.
    Schwarzwald
    Feb 2007
    107
    POLAR,,,,,,,
    Jan 2006
    4396
    Crap!!!
    LOL, post this in the Mastercam area, maybe someone there can help.
    Sorry.
    Toby D.
    Schwarzwald
    Feb 2007
    107
    HEY,,,,,
    THANKS ANYWAYS. I JUST MIGHT TRY IT LONGHAND.
    BAD DOG
    Nov 2007
    188
    18 PITCH N.P.T. THREAD MILL USING C AXIS
    I run this on my Puma 2500 SY
    1/4-18 PITCH N.P.T. THREAD MILL USING C AXIS AND LIVE TOOLING
    N30T1111(27/64" DRILL)
    M24
    G99
    G54.1P1
    G97S1500M3
    G0X0.Z1.M8
    Z.1
    G1Z-.945F.004
    G0Z1.M9
    M5
    M1
    N40T0909(1/4 N.P.T. REAMER)
    M24
    G99
    G54.1P1
    G97S1000M3
    G0X0Z1.M8
    Z.1
    G1Z-.9F.012
    G0Z5.M9
    M1
    N50T0707(3/4 45 DEG. CHAMFER)
    M24
    G99
    G54.1P1
    G97S3000M3
    G0X0Y0Z1.M8
    Z0
    G1Z-.185F.006
    G0Z5.M9
    M1
    N60T0808(18 PITCH N.P.T. THREAD MILL)
    M24
    G54.1P1
    S2315M33
    G0X0Z.1C0M8
    G98
    G1Z-.6F50.
    X.168Z-.5725H180.F7000.
    Z-.5169H360.
    X0Z-.4891H180.
    G0Z5.M9
    G99
    Dec 2011
    34
    Re: NEED THREAD MILL PROGRAM FOR C-AXIS
    I know this is an old thread but have you figured it out? I just had success programming a thread mill but using Cartesian to polar coordinate transformation on my fanuc control wouldn't work.use the y axis trust me. That way you can use the radius offset in your offset page which controls the y axis to control the dia like g41 cutter comp on a mill works.i can post an example if u want.im just replying to put the info out here in case you come across this again or it helps someone else.Best of luck
  1. Thread Mill Program
    By october in forum G-Code Programing
    Last Post: 07-20-2016, 02:36 AM
  2. Question on thread mill program
    By JRTurner in forum G-Code Programing
    Last Post: 04-04-2013, 10:27 PM
  3. Sample thread mill program
    By Captdave in forum HURCO
    Last Post: 03-11-2010, 02:37 AM
  4. Need help with simple thread mill program
    By Captain Midnigh in forum Milltronics
    Last Post: 07-24-2008, 11:57 PM
  5. 2-1/2 - 8 NPT Thread Mill Program
    By wesleybridgepor in forum MetalWork Discussion
    Last Post: 11-30-2006, 11:56 AM
