585,932 active members*
3,684 visitors online*
Results 1 to 2 of 2
    Jul 2014
    1
    Need Help Programming Actions!
    I need to cut out about 300 Steel squares with a hole in the middle of each of them. The issue I'm facing is that the laser CNC wants to cut the squares out first and then route back to cut the holes. Well the problem is, the squares drop down into the coolant when the are cut so, the holes can't be cut after that. How do you program it to cut the holes first, then come back and cut out the squares?
    Dec 2005
    594
    Re: Need Help Programming Actions!
    Sounds like a CAM programming issue?
    What CAM are you using?
  1. Xilog 3 Parametric Programming Offline Programming
    By julioykaly in forum Commercial CNC Wood Routers
    Last Post: 04-27-2013, 09:22 PM
  2. IGF programming
    By a00509265 in forum Okuma
    Last Post: 03-27-2012, 05:17 PM
  3. 1993 haas VF-2 Alarm Actions
    By tbussan in forum Haas Mills
    Last Post: 03-02-2012, 07:21 PM
  4. milling hard rifle actions
    By elc in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 11-03-2010, 02:19 PM
  5. PC to Fanuc proper actions.
    By Schljuutene in forum DNC Problems and Solutions
    Last Post: 08-10-2010, 06:47 AM
