585,925 active members*
3,633 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Need help! Linux CNC converted Correa A10 strange Z sound
Results 1 to 9 of 9
    Dec 2006
    112
    We have converted an old Correa A10 to Linux CNC and when we run the Z-axis up and down we get a strange pounding sound that was not there before the conversion.
    The Z-axis has some kind of hydralic compensation for the weight which we cant find much info about and maybe that is causing the sound?
    It also has a brake or clutch but we have tried to remove that.
    Any ideas?
    Aug 2014
    161
    Re: Need help! Linux CNC converted Correa A10 strange Z sound
    You may be moving the z axis too fast. Hydraulic it probably has valving and your causing it to over pressure and possibly relieve through a bypass. That could be the pounding you hear. Try slowing down to see if the noise subsides.
    Dec 2006
    112
    Thanks for you answer.
    We are on the same track but the sound is there even when we move it slowly, although the frequency increases with the speed.
    I think we may have missed something that was regulated by the old controller, how would this kind of hydralic weight compensation be regulated?
    Aug 2014
    161
    Maybe there is a solenoid somewhere in the system that blocks fluid flow while powered off. So with the new controller you are forcing fluid through the bypass circuit. Maybe. Get some pictures posted up of lines or anything related to the hydraulics.
    Mar 2004
    1661
    Aah, SWEET! Oh man so many hours I've spent by a C A10 and A16.
    Can you record it? Even the crappiest phone video and a youtube upload will help a lot.
    If you replaced the drivers with new ones they might have different behaviour causing the motors to shatter etc. It can be the hydraulics too, who knows...
    Dec 2006
    112
    We can record it
    We did not replace the drivers, we control them with a Mesa 7i77 analog servo card.
    What do you mean by shatter?
    Aug 2014
    161
    i think he meant chatter.....or shudder could be interpreted the same. post the vid so we can help
    Mar 2004
    1661
    Off coarse Eye meen chatter.
    Aug 2014
    161
    Quote Originally Posted by svenakela View Post
    funny lol
  1. Hello from New Zealand, does anyone Have a Correa A10 or A16 CNC mill ?
    By jacel in forum Australia, New Zealand Club House
    Last Post: 07-20-2014, 12:29 AM
  2. Steppers not missing but making strange sound.
    By jwolin in forum DIY CNC Router Table Machines
    Last Post: 05-15-2012, 12:39 AM
  3. VIDEO of a Bridgeport Series II Interact 2 CNC mill converted to Linux/EMC
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 07-24-2010, 01:44 AM
  4. Strange error on a CNC converted Industrial Hobbies mill
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-12-2006, 12:35 AM
