Re: Need help getting my initial set-up to work.
I'm guessing the Aspire and Mach3 came supplied with the machine? If so, they're likely pirate copies, although that's the first time I've seen Aspire supplied if so. But to answer the questions, Mach3 in demo mode only processes the first 500 lines. So far as your Z axis being off, Aspire has a "Safe Z" setting that affects Z height clearance, in addition to the material location on the design area, and the "Material Setup" screen also has options for setting the Z reference in regard to the material.
And in addition to any 0,0 references in Mach3, Aspire also has a job setup that defines the 0,0 reference, so if your setting your job up in Aspire to be central to the crosslines, but Mach3 has home of 0,0 being front left for example, the job will start machining to the right and back.
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
