584,842 active members*
4,311 visitors online*
Results 1 to 2 of 2
    Jul 2014
    2
    Need Help Cutting cardboard
    Hi, please forgive me if I am in the wrong place but I can not find any info anywhere and need your guys help, I have purchased one of those cheap ebay lasers for about 400 GPB, it uses Winseal software, I need to cut out a template but the laser cuts around the inside line and outside line of the template is there anyway that I can rectify this. It does cut out the template but obviously takes double the time and also catch fire when it goes round the previous cut. please help. Thanks in advance.
    Nov 2012
    492
    Re: Need Help Cutting cardboard
    I don't know this software but you need to have your cut lines set as hairline, and you should only have one cut line. Low power fast speed for cardboard.
  1. Need Help Cutting cardboard
    By pz22pz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-30-2014, 02:06 AM
  2. DIY Cutting machines for cardboard or chipboard
    By the1toyplace in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-06-2013, 11:43 PM
  3. Cutting slots in cardboard tubing
    By Devastator in forum CNC Tooling
    Last Post: 08-08-2012, 05:38 PM
  4. Laser power for cardboard cutting
    By lucareds7 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-31-2011, 05:45 PM
  5. accurate cardboard cutting?
    By settle in forum Material Machining Solutions
    Last Post: 01-31-2008, 04:49 PM
