Hello all,
Thought I would share what i have created with my homebuilt cnc.
It is only a small desktop machine with a cutting area of X-370mm, Y-285mm, Z-70mm with an Ozito 850w router for spindle driven by SuperPID (best purchase ever!), 3A Nema23 steppers driven by the Massmind.org thb6064 driver kits.
This is just a hobby for me and a thoroughly enjoyable one at that.
So enough natter and on with the pics
Here is the latest creation, a ball bearing maze made from mdf and clear acrylic.
These were my own design drawn up in bobcad v24.
Just single sided with an 11mm diameter steel ball.
Attachment 214812
This is another maze, but this time 2 sided and a bit smaller using 8mm steel ball (2 or more balls to make it a bit more of a challenge)
Side 1
Attachment 214814
Side 2
Attachment 214816
Some V-Carvings from a little while ago. done with a 90degree v bit.
These were just images taken from google and vectorized
I stained the mdf first then carved it with some of them.
Attachment 214818
Attachment 214820
Attachment 214822
Attachment 214824
Couple of 3d puzzles
Purchased the landrover plans from Makecnc.com, well worth it as you get very detailed assembly instructions and dxf files for both mm and inch.
Attachment 214826Attachment 214828
Attachment 214830
Bought a rotary axis from fleabay for $280 and had a bit of a play.
Attachment 214834
Attachment 214836
Attachment 214838
Did a few Lithophanes with the 4th axis on white pvc pipe, lit up with led torch in the first one
Attachment 214840Attachment 214842
This one i painted the pipe black first and carved a base and top for it and lit it with led strip light.
This is my sons night light now, he loves it!
Attachment 214844Attachment 214846
Attachment 214848Attachment 214850
And another V-carve, different method this time. Still just an image from google and vectorized but stained the mdf black before carving.
Attachment 214852
I have done a lot more but didn't take photos of them and have gifted them away.
I will post more pics of creations as i do them or find pics of
Feel free to ask any questions about machine and what not, be glad to share.
Such an addictive hobby that's for sure
