585,602 active members*
3,460 visitors online*
Results 1 to 6 of 6
    Oct 2009
    19
    More hassel with the haas
    20mmx70mmx12mm billet just want to round both ends with a 10mm rad
    prog will not run does any one know why when should be such a simple thing to do!
    O99998
    (SAFETY START LINE)
    G90 G00 G40 G80 G98 G17 G21
    (G10 G54 SET LINE)
    G10 L2 P1 X-358.3 Y-191. Z0.
    (G54 WORK OFFSET)
    G90 G00 G54
    T8 M06
    G00 G53 Z0
    G90 G00
    G43 Z50. H08 D08
    S1000 M03
    G00 X-35. Y-35.
    Z2. M08
    G01 Z-10.F2000
    G41 G00 X-10. Y-25. F2000
    G02 X10. Y-25. ,R10
    G00 Z2.
    X10. Y25.
    G01 Z-10.F1000
    G02 X-10. Y25. ,R10
    G00 Z10 M09
    G40
    G00 Z150. M05
    Y150
    Mar 2014
    19
    Re: More hassel with the haas
    If I'm not mistaken your feeds should have a decimal as well as the radius... All X Y Z F and R need a decimal after. Gosh looking back it seems like there's like 8 spots missing decimals and I don't think camas are supposed to be there. Were u hopped up on coffee when u wrote that code?
    Feb 2011
    353
    try taking the comas out in front of the radius i believe that that is used to create a radius between two lines (g01) and not a full arc in g2/g3
    Oct 2009
    19
    The machine is only 2 years old and has worked every day and very rarely on the same prog. it does not need dots and splogs as suggested by the coffee man altho the lack of the commer in front of the R command is something i will try many thanks.
    for anyone reading this and wants to buy a haas try to get with a hiedainain control, or just simply buy a bridgeport.
    Oct 2009
    19
    Quote Originally Posted by rcs60 View Post
    thank you
    Feb 2011
    353
    your welcome
  1. Replies: 4
    Last Post: 06-28-2013, 02:00 PM
  2. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  3. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
