Re: Mini Mods.
I put a brass drain set up on my compressor.
I have a 3.5 HP Kaeser Screw Compressor on a 60 gallon tank. I put a 1/4 inch brass elbow in the bottom of the tank and from there I ran a brass pipe out to the side of the tank where I put another brass elbow pointing straight up. In that brass elbow, I put a disconnect for an air line. Now, I can just plug in an airline and let the pressure in the tank push any water out.
This time of year, sometimes I'll get 2 gallons of water a week.
I'll squirt the water into a 3 gallon jug, then set it outside to evaporate. You wouldn't believe how rusty the water coming out of the compressor is.
