585,951 active members*
4,332 visitors online*
Results 1 to 8 of 8
    Sep 2014
    2
    Measured power of 'ebay' lasers vs advertised rating
    Hi guys,
    How many folks measure their tube output? I'm curious to see how close to the rated output other peoples tubes are.
    If you do measure your laser output, please could you let me know the advertised tube wattage and the actual output power you measured? I'm hoping many people will find this useful as a resource of what to expect, and it would help me with my issue below:
    In my particular case; I recently bought a 50W laser cutter from ebay. I had some teething troubles, the laser power supply was broken on arrival - but was replaced, and now I'm reasonably happy with it. I also bought a Mahooney 100W probe.
    The machine:
    Attachment 251062
    Attachment 251064
    Attachment 251066
    According to my probe I am currently getting about 29W output direct from the tube aperture - whilst pulling 27mAh from the supply. For a 50W laser, I'm fairly disappointed with the power output, and can just just about get through 5mm plywood on full power (slowly, and often requires multiple passes). Does this stack up with other peoples experiences?
    I'm considering buying a replacement tube from a local source and have a choice between 40W and 60W tubes. If a 40W tube will really put out 40W, then its probably in my interests to 'downgrade' - as it'll mean a 10W increase over my current scenario. If not, then I'll probably spring for the 60W version.
    Thanks for taking the time to read my thread.
    Kind regards,
    Gareth
    Feb 2012
    387
    Re: Measured power of 'ebay' lasers vs advertised rating
    5mm plywood ,60w should cut and for 40w ,50w ,their power is almost same ,max is 40 -50, but 29w is too small
    Quote Originally Posted by holozip View Post
    Hi guys,
    The machine:
    Attachment 251062
    Attachment 251064
    Attachment 251066
    the 40w tube should be same as the 50w one , max can reach 50w ,yours is only 29w, seems not normal and for 5mm plywood, 60w should work,if it can reach 60w
    Kind regards,
    Gareth
    Lucy Lee G.WEIKE LASER
    [email protected]
    Nov 2010
    787
    As for standard chinese lasers:
    700mm long is about 32-35W when new in good condition (not 40 as they claim)
    1000mm is about 50W if you are really lucky guy.
    1200mm can reach 55W. 60W when just out of factory line.
    Regards
    CNC lasers, constructions, service
    Sep 2014
    2
    Thanks for the responses guys. I ended up going for a 60W tube and matching power supply to solve my issue:
    Attachment 251470
    Attachment 251472
    As predicted, I'm getting around 55W - which should be more than adequate for my needs.
    Nov 2008
    382
    hi all
    as to CO2 laser tubes it depends where the manufacturer are. over the years I had 40W tubes from different sources but during the last two years I bought tubes from the north branch and they last about 1,500 to 1,800 hours heavy cutting.
    I cut 5 and 6mm plywood mostly just the cheap from HD and I can cut them with around 15mA and a speed from 5 to 8mm/s one pass. sure there are some batches of plywood who have lots of glue inside and they are tough or not cutting at all, they go in the waste.
    greetings
    waltfl
    Jun 2010
    4256
    I'm curious - can you cut thin sheet metal with any of these? eg Al or Ti?
    Cheers
    Roger
    Nov 2008
    382
    no you can not cut any metal with a CO2 tube , maybe with a high power over 200W but I don't know about this
    greetings waltfl
    Sep 2014
    123
    Cut no.. But if you spray the aluminum with a laser prep material, its like a special paint, then you can etch designs into it and wash away the excess. I have seen it done its pretty neat and works on aluminum and stainless steel.
  1. S6 Power Rating - What Does it Mean?
    By TMDE in forum Phase Converters
    Last Post: 08-29-2010, 01:01 AM
  2. POWER RATING PLEASE HELP
    By 15mgtar in forum Stepper Motors / Drives
    Last Post: 10-22-2009, 10:11 PM
  3. * Any idea? How to get Power Rating and RPM of stepper?
    By cjchands in forum Stepper Motors / Drives
    Last Post: 04-18-2007, 04:53 AM
  4. CO2 lasers on ebay.
    By owhite in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-28-2005, 11:18 PM
