585,973 active members*
4,138 visitors online*
Results 1 to 7 of 7
    Oct 2006
    137
    Mastercam Post
    Im looking for a Tormach Mastercam post for X5 that supports metric and the ATC? Can anyone help?
    Will
    May 2013
    63
    Re: Mastercam Post
    I don't know about the ATC, but I use the basic Fanuc (MPFAN) post for mine and it works fine.
    Aug 2011
    135
    Re: Mastercam Post
    Atc shouldn't need any special post processing
    Sent from my SM-G900V using Tapatalk
    Jan 2012
    139
    Re: Mastercam Post
    The ATC doesn't need any special post from Mastercam. All that's needed is an M6 and a tool number and the control will handle the rest.
    www.benchtopprecision.com
    | BF20/G0704 Belt Drive Kits | X2 Mini-Mill Belt Drive Kits |
    Sep 2012
    1543
    Re: Mastercam Post
    Example
    M6 T10 G43 H10
    It doesn't need an M998 or whatever it is
    Jun 2013
    5
    Re: Mastercam Post
    Look on the tormach yahoo group. There are mastercam posts on there.
    Cheers
    Oct 2006
    137
    Re: Mastercam Post
    Thanks for the replies, I had worked it out my self, i edit the code produced by master cam as per Bamcnc's example M6 T10 G43 H10 and it works fine,( Mastercam breaks this up over a few lines) if you are only using a couple of tools and don't have the ATC setup the machine stops for a manual tool change.
    Will
  1. mastercam post
    By dahab in forum Post Processors for MC
    Last Post: 07-17-2009, 04:36 AM
  2. kia post for MasterCam
    By bradmancue in forum Post Processors for MC
    Last Post: 07-10-2008, 01:44 AM
  3. Post for Haas vmc in Mastercam or post help
    By bob1112 in forum Haas Mills
    Last Post: 03-03-2008, 12:09 AM
  4. mastercam x post
    By mrwright in forum HURCO
    Last Post: 01-10-2008, 10:25 PM
  5. please help with mastercam v9 post
    By gasho in forum MetalWork Discussion
    Last Post: 12-01-2006, 03:53 PM
