585,930 active members*
3,699 visitors online*
Results 1 to 8 of 8
    May 2011
    92
    Question Mach3 TouchScreen Problem
    I use a 15" LCD TouchScreen w/ Mach3.
    Twice this has happened. While using the Mach3 Jog button, the axis will stay running after my finger is released.
    I have a good idea its from oil leftover on the screen from my finger that the touchscreen is sensing.
    Anyone have a similar problem and what to do about it ?
    Aug 2008
    962
    Re: Mach3 TouchScreen Problem
    I have,
    My touch screen is very sensitive to moisture & I use flood coolant, so ... I keep a towel hanging within convenient reach & have trained myself to dry the hands before touching the screen.
    May 2011
    92
    Initially I thought it was the mouse doing this.
    There is no sensitivity adjustment on this ELO 1715L. And yes it is very sensitive to touch.
    Ill try a phone screen protector on the jog button area.
    Mar 2005
    305
    After two incidents of the same nature, I removed my touch screen
    Sent from my SM-G900V using Tapatalk
    Sep 2011
    14
    I have a brand new Dell #2014 touch screen on my G0704 with Mach and I have come to the conclusion that a touch screen is just not suitable for crucial functions in Mach 3. I use the ts for quick data input, but I use either a imach pendant or a wireless keyboard for actual movement functions. The TS is just not reliable enough for crucial situations. As said above, the jog buttons sometimes stick from skin oil or they just don't activate true as they should. My advice is to save your money on a ts and buy a good pendant instead
    Sent from my Samsung Galaxy Note 3.
    Nov 2009
    4415
    Seems like the towel was a cheap solution that allowed you to have the best of both worlds.
    A lazy man does it twice.
    Sep 2005
    371
    Really like my touchscreen but I don't use it to jog or as said above, anything crucial. I use an XBox controller for jogging around.
    And yeah, I keep a towel close by too.
    May 2017
    2
    Hi Guys
    I have Mach3 running on a PC with a touchscreen. When I hit tab to bring up the jog screen, the arrows for jogging do not respond with touch - they only work with mouse clicks.
    Any ideas?
  1. Mach3 with touchscreen
    By Falcon69 in forum Mach Software (ArtSoft software)
    Last Post: 06-19-2013, 01:56 AM
  2. Keypad/Touchscreen
    By mmckell in forum Cincinnati CNC
    Last Post: 02-07-2012, 07:05 PM
  3. A2100 touchscreen
    By dude-ler in forum Cincinnati CNC
    Last Post: 12-14-2010, 02:55 AM
  4. Replies: 1
    Last Post: 02-10-2010, 07:06 AM
  5. touchscreen keyboard ?
    By dertsap in forum Mach Wizards, Macros, & Addons
    Last Post: 02-07-2010, 02:03 AM
