585,727 active members*
3,940 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach3 Safe Z not returning to work surface after Stop...
    Sep 2014
    123
    Ok, so i am fighting an Auto Z problem, see my other post, and i noticed another problem with Mach3 today.. Is this software just this buggy or what???
    So i have Safe Z turned on, and its set to retract to +3.00 when stop is pressed. So i was testing it and noticed it doesn't work anything like i thought it would.
    Running some code and its moving around, click Stop, the axis's stop moving, the bit retracts to +3.00 above Zero, awesome i thought, but when i click Cycle Start to continue where it left off the bit stays at +3.00 for the rest of the program cycle. Why doesn't it automatically go back down to Zero and then to the working depth and continue???
    35538
    Re: Mach3 Safe Z not returning to work surface after Stop...
    Because when it resumes running the g-code, there is no Z command to tell it to go back down. It's working exactly as it's supposed to.
    Be aware that when you click "Stop" while the machine is moving, it will almost always lose steps, and attempting to resume cutting will usually result in a damaged part.
    If you want to resume after stopping, you need to use feedhold first, and then stop, AFTER the machine has stopped moving.
    To resume, use Run From Here, but, you need to start at a point in the g-code where the Z axis will move down to cutting depth.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2014
    123
    Hmm ok.. So i would have to Feed Hold, the Stop, but it still wouldn't work because it would need the Z code to go back down. I will have to play around with this some there has to be a better way.
    Thanks!
  1. Replies: 6
    Last Post: 03-18-2013, 11:42 PM
  2. How to stop table from returning home every tool change
    By david martin in forum Mastercam
    Last Post: 06-21-2011, 12:43 PM
  3. Returning to safe Z.
    By Dougal in forum CamBam
    Last Post: 11-08-2010, 08:56 PM
  4. Replies: 30
    Last Post: 11-02-2010, 09:09 PM
  5. Z Safe when stop
    By diltech in forum LinuxCNC (formerly EMC2)
    Last Post: 08-18-2008, 04:09 PM
