I am servicing a Fanuc power supply and am looking for a pinout for Fanuc IC HA16630G.
Thanks,
Thanks,
Look in the datasheet!
I have not been able to locate a datasheet for this device. Do you have one?
Attachment 216852
what's on?
Thanks. All the supplies look good and clean. It is the voltage monitor circuitry that is failing. The output (pin 9) is at 8v where should be at zero volts to drive the control circuit. Pins 3 & 23 are at 0v where they are at +14V on a good board. Thus the System Enable line is signaling a failure to the rest of the system. I suspect this IC is bad. I found one on ebay. I guess I will try it.
Thanks again
I faced with bad voltage monitor in this IC two times. added an ordinary voltage supervisor and all is ok
Not a bad ideal! Do you monitor just the 24V supply or the +-15V supplies also?
Can you send me datasheet of IC HA16630? I have trouble same to you, I have been trying to find it but i haven't found any ones. Or Can you give me some advance?
The only we have is that schematics, from what we can see where to add supervisor
thanks for help. i have solve my problem
