585,749 active members*
3,885 visitors online*
Results 1 to 2 of 2
    Oct 2006
    26
    Limt switch problem
    In Mach3 mill I get a "external E-stop requested" and cant reset. On the diag.screen all 3 limit switches respond when manualy tripped. If I disconnect the common lead from the X, Y, & Z limit switches, (but not the E stop) then I can reset as normal. ?
    Oct 2006
    26
    Re: Limt switch problem
    I eventually removed and re-installed the program and all was well.
  1. A different Limit Switch Problem
    By bamabones3 in forum Chinese Machines
    Last Post: 02-23-2012, 08:00 PM
  2. Limit switch problem
    By paulb in forum DIY CNC Router Table Machines
    Last Post: 07-13-2009, 11:49 PM
  3. switch bounce problem
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 07-12-2009, 09:59 PM
  4. Limit Switch Problem
    By tz1238 in forum Machines running Mach Software
    Last Post: 02-07-2008, 11:00 PM
  5. Limit switch problem
    By jimini in forum Mach Software (ArtSoft software)
    Last Post: 09-18-2007, 02:49 AM
