585,991 active members*
5,407 visitors online*
Results 1 to 2 of 2
    Mar 2015
    1
    Lightning CNC
    I just put together my 5x10 m4 lighting table and i tried moving it around and only my y axis works my x axis is making a wierd noise and wont move it just vibrate and shakes a little bit. I took one of the y motors and plugged it into the x plug in and it does the same thing so i know the motor it fine i think it is something in the software settings and i cant figure it out. the machine came with an hp pc and mach 3 (demo) software, does anyone know what i might be able to do to get it running or know of what software i need to buy for it to make it work?
    Jun 2008
    562
    Re: Lightning CNC
    Try this, there could be an easy?? fix. :CNCCookbook: Debugging CNC Electronics
    Sounds like motor is way out of tune or pins and ports are wrong
    Mike
  1. Lightning CNC
    By scarecrow in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 10-01-2014, 03:30 AM
  2. LIGHTNING CNC
    By kkinser99 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-23-2014, 02:16 PM
  3. My experienc with Lightning CNC
    By OldEngr in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 03-02-2014, 09:30 PM
  4. lightning
    By slowlearner in forum Cincinnati CNC
    Last Post: 06-27-2011, 03:24 PM
