I have a Leadwell MCV 760 XL machining center with a Fanuc 10M control. I have been dealing with a spindle problem where I only have 2 spindle speeds the first is if the programmed speed is at or below 1000 rpm, and the second is at 1001 or higher. I can enter any number as a spindle speed have used 100,000 and the control will not alarm even though the machine only runs to 6,000 rpm.
I have asked the machine side support, and they say it is a fanuc problem,when I ask fanuc, they say it is a machine problem, so I am getting nowhere.
I have replaced the sensor at the top of the spindle motor under the fan. This made the motor run better manually,although it is still a bit rough.
So we started to machine some steel bars with the spindle running at the higher speed and it was working ok, but just a bit too fast. we stopped running to change inserts,when we started again,the machine milled about half way across the part and stopped. the spindle motor was turning but the spindle wasn't, and although the spindle was down in the cut, the tool carousel was turning!
hit E-stop and the machine shut down, released it and started doing the same thing. could not shut the control down either.
The next day, powered up the machine, zero returned all axis and the machine was on but not running. an hour later, the spindle motor was running, tool not spinning, the carousel was turning, and the coolant pump was running and again, the control could not be powered down.
This machine is an important part of our operation and needs to be fixed. Replacing it at this time isn't an option. Any help would be greatly appreciated.
