585,973 active members*
4,198 visitors online*
Results 1 to 2 of 2
    Apr 2009
    1
    Question Laser controller help needed please
    Hi All
    I am about ready to throw my laser cutter in the trash - My laser cutter had a Leetro MPC03-LV controller in it and suddenly died - I purchased a new controller to swap in and made no difference the machine was not found by my PC. (dreaded PCI connection)
    This lead to my purchase of the PH3 usb controller. I installed all the components and the PC has no problem connecting to the machine.
    I can move the laser head on X and Y axis with no issues using both the control panel and software on the PC - the laser head fires when the "light" button is pressed. The issue I am having is the laser will not respond to any files - the display will show as though it is cutting and the machine does nothing.
    This issue has driven me crazy and any help would be great.
    thanks
    Ferd
    Jun 2014
    611
    Hello Ferd, this is Nolan from Thunder Laser.
    what a pity you can't use your new controller. I have used Leetro, PH and Ruida controller before, you installed all the components and the PC has no problem connecting to the machine, I think the problem is your PH controller. In my experience, PH controller is not very stable, maybe you can connect with your PC, but you really can't input any files to your PC, I have this problem while I use PH before.
    so I suggest you should buy a Leetro controller. and it is my guess, I am not sure if you change the controller, then you can use your laser again.
    our company use Ruida controller now, maybe these videos is useful to you.
    How to use laser software - Thunderlaser
  1. Laser engraving machine not firing laser from software or controller.
    By JustTruckinng in forum Engraving Machines
    Last Post: 05-14-2014, 04:14 AM
  2. Servo Controller help needed
    By c12mech in forum Stepper Motors / Drives
    Last Post: 07-09-2013, 05:16 PM
  3. Help needed on FAGOR controller
    By CNC_Geek in forum G-Code Programing
    Last Post: 10-09-2011, 08:42 PM
  4. Syil c6 cnc controller box needed!!
    By gglynn81 in forum Syil Products
    Last Post: 09-19-2008, 12:29 AM
  5. sinumerik 805 SM controller help needed
    By jrajasekar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-28-2007, 07:18 PM
