585,987 active members*
4,436 visitors online*
Results 1 to 2 of 2
    Sep 2014
    1
    Integrex Head Index Position
    Im running a long part where Im using the second spindle as a tailstock. When it tool changes to the drill I need, the head wants to index to 90 deg and it will hit the second spindle. I was able to set a TPC (index position) to have the head move towards spindle 1 before indexing to 90 but my problem is when the drill is done, instead of going to the TPC point, it wants to return home before indexing back to 0 degrees. But that's a crash in to the second spindle. How do I get the head to index on the departure in a different spot than home? Any help would be greatly appreciated.
    Oct 2010
    7
    Re: Integrex Head Index Position
    What we often do is send the Z2 to home before the tool change in a manual program and bring it back afterwards in another manual program.
  1. Mori NL2500 Turret index position
    By BROCD in forum Esprit
    Last Post: 03-05-2013, 05:07 PM
  2. (ESPRIT)G28/G30 OR G54 TURRET INDEX POSITION
    By BROCD in forum Uncategorised CAM Discussion
    Last Post: 03-01-2013, 06:55 PM
  3. using encoder index for homing and a axes position
    By rokag3 in forum CNC Machine Related Electronics
    Last Post: 10-16-2009, 12:57 PM
  4. Mazak Integrex 1060v8 c axis position errors
    By Bushman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-29-2007, 10:28 PM
