Industrial cross generating laser alignment adopts import laser diode and import glass cylindrical lens, realizing the most stable and reliable two perpendicular line generations in various industrial working fields. It is very easy and convenient to install, operate and adjust.
Cross laser alignment can realize visible and invisible infrared cross generation in practical use. It is widely used in textile garment positioning, car wheel positioning, medical equipment CT/CB and magnetic resonance imaging lesions, cutting positioning etc.
In practical cross generating working fields, cross generating laser alignment can be easily mounted and installed on certain machine or equipment with the assistance of mounting bracket. This laser diode cross line laser beam emitting alignment laser always assures the most efficient 90 degrees cross measuring. This laser alignment tool has featured advantages of low energy consumption, high efficiency green laser beam output.
