585,752 active members*
3,871 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Importing STL File Problem
Results 1 to 6 of 6
    Jun 2012
    2
    So i have some files I have made in Solidworks that are 3D files that I saved an as STL file. I can get them imported into ArtCam, but when I try to run the 3D toolpath it does all of the processing of the toolpath but it doesn't complete it how the file should look. There are saw teeth like marks all over the sides that should be straight and others that aren't cut out fully. The bit I'm using is a 1/4" upspiral flat bottom bit for both passes as the machine I use, a Probotix Fireball Meteor, doesn't have a bit change and I only know how to get it to do 1 bit per program as I am still new and learning CNC'ing.
    Any ideas on what I can do to get this to turn out right would be greatly appreciated.
    Thanks in advance,
    Dan
    Solidworks Top View:
    Attachment 243710
    Solidworks Iso View:
    Attachment 243712
    ArtCam Iso view:
    Attachment 243716
    How the ArtCam file looks after the toolpath is done:
    Attachment 243714
    35538
    Re: Importing STL File Problem
    Using an .stl file and ArtCAM is the wrong approach for that type of part.
    A 2.5D CAM program will give much better results, in much less time.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2009
    87
    You could also save it as a DXF, then use lazy cam.
    proper planning prevents piss poor performance
    Jun 2012
    2
    Is there a 2.5D CAM Program you would recommend? I have drawn them in 2D in draftsight/acad, but I'm looking for an easier way to get the toolpaths and importing done as I design everything in solidworks at first that way I can make sure it all fits together when the parts inside of the part are assembled.
    35538
    Gerry
    Aug 2014
    12
    Hello,
    These saw marks are usually caused by the step over. I usually use a larger step over for roughing then take the step over on the finishing path to as little as possible (depending on how long the job would take.) If that doesn't work, i guess you are using the raster option? give the offset option a go and see what finish that gives? you could also change the angle of the raster offset and try that.
    Please post your results would be interesting to know the problem.
    You may also want to have a read through the machine relief guide which can be found here: http://moodle.tcaps.net/pluginfile.p...ine-relief.pdf
    Just to make sure you have everything set up correctly
    Cheers
    George
  1. Problem importing ArtCam Pro file to NCstudio
    By dancingdragon in forum ArtCam Pro
    Last Post: 02-28-2016, 08:43 PM
  2. File importing
    By oknups in forum OneCNC
    Last Post: 03-09-2011, 10:48 PM
  3. importing igs file
    By Cartel, LLC in forum BobCad-Cam
    Last Post: 04-27-2010, 02:39 PM
  4. Problem importing bmp file
    By ChetR in forum Dolphin CAD/CAM
    Last Post: 03-26-2010, 09:03 PM
  5. Importing Rhino File
    By buggie in forum Mastercam
    Last Post: 04-13-2009, 06:51 PM
