585,931 active members*
4,407 visitors online*
Results 1 to 4 of 4
    Jan 2006
    121
    I need only cable number to Fanuc - Dah Lih
    My Cable on X-axels was really bad condition and I look on ebay but without any spec number I was out of access.
    The Cable have 20 lines and on the servomotor it an Amphernol / Cannon Contact. Other side is an Honda.
    The machine is an DahLih MCV 510 made 1993.
    Maybe any now from where I can find the Cable. I have wrote a letter to the manufacturer but the don´t answer me
    The best is of course to find a complete original cable but also a corresponding noncontact second. The old cable was broken because of the cutting fluid that dissolved the cable cover.
    The servo motor and amplifier is manufactured by Fanuc RedTop at 900 watts.
    Probably, someone changed the cable once since the 20 pin cable is a signal cable.
    Power cable goes in a separate cable.
    Attachment 233002
    Dec 2003
    24221
    Re: I need only cable number to Fanuc - Dah Lih
    In most cases, especially with older machines, the responsibility for replacement cable is for the owner to obtain these by getting a technical service company to make these up, the originals are usually custom from the OEM.
    The one shown is the standard Fanuc MS connector.
    Al.
    Attached Files Attached Files
    Albert E.
    Jan 2006
    121
    Thank´s Al for the information,
    the other connector named as H20 Honda Tsushin MR connector, 20 pin. Maybe I can find this on www..
    Dec 2003
    24221
    There is not that many sources for Honda plugs, unfortunately, they come in two types, the solder type and the crimp pin type.
    Al.
    Albert E.
  1. Fanuc Serial Number Macro
    By TomL21 in forum Parametric Programing
    Last Post: Yesterday, 06:16 AM
  2. Fanuc 0M number and dripfeed?
    By jeppes in forum Fanuc
    Last Post: 07-12-2023, 05:15 AM
  3. Replies: 1
    Last Post: 06-24-2013, 04:50 AM
  4. Fanuc Oi-md Pot vs Tool Number
    By muddobber76 in forum Fanuc
    Last Post: 09-26-2012, 09:45 PM
  5. Replies: 1
    Last Post: 08-22-2007, 06:39 PM
