I am building my first CNC and have been through many websites trying to gather information on this subject.
Essentially there are few approaches to this subject
-The first mostly used is the mechanical approach when we try to calculate forces( torque) necessary to overcame friction, the force for grinding the material or to provide acceleration when start/ stop or making corners. This path is very scholastic and requires advanced knowledge.
-Second is something experimental when we build a machine or try to copy somebody else’s machine and realize it has to be improved and start looking for solutions.
And the third method I shall name it value for money; we try to choose the best parts we can afford for a given budget. The idea was borrowed from Tom’s hardware web site- building the best desktop PC for a budget.
I have chosen 4 stepper motors from e-bay and we will compare them:
The torque produced by the rotor is directly proportional to the current in the armature windings. The proportionality constant is the torque constant of the motor.
Model Current(A) Resistance(Ω) Inductance (mH) Holding torque(oz.in) Connection Price 23HS9430B 3 1.6 6.8 425 4 leads 30GBP 57BYGH41-401A 2.8 0.7 1.4 76 4 leads 16.5GBP 57BYGH627 3 1.6 3.5 270 4 leads 27GBP 23HS45-3008D 4.2 0.4 1.7 354 bipolar parallel 8 leads 39GBP 2.12 1.6 6.8 240 bipolar serial 8leads 39GBP
Mo = I x Km
Mo = torque developed at rotor
kM = motor torque constant
Therefore 23HS9430B at half of maximum current will have half torque 212 oz.in and so on.
But we have to consider we always need the dynamic torque, when the motor is spinning.
Now comes into play the inductance which starts limiting the current.
U=L x ∆I/∆t or considering only amplitude U=ώLI ; Ohm’s law for inductance
We choose the power supply 36V and f=1000hz. To simplify I am going to ignore the resistance
ώ=2πf=2x3.14x1000hz.
I(6.8mH)=36/(6.28x6.8)= 0.84A
I(1.4mH)=36/(6.28x1.4)=4.09A
I(1.7mH)=36/(6.28x1.7)=3.37A
I(3.5mH)=36/(6.28x3.5)=1.63A
The torque at 1000hz is: maximum torque x current/maximum current
23HS9430B 425x0.84/3=119 oz.in
57BYGH41-401A (the limit current is 4.09A greater than maximum current) 76 oz.in
57BYGH627 270x1.6/3=144 oz.in
23HS45-3008D bipolar parallel 354x3.37/4.2=284 oz.in
Bipolar serial 240x0.84/2.12=95 oz.in
This is the torque we are interested of:
Model Torque 0hz Torque 1000hz Price Torque/price(bigger is better) 23HS9430B 425 119 30GBP 3.96 57BYGH41-401A 76 76 16.5GBP 4.6 57BYGH627 270 144 27GBP 5.3 23HS45-3008D 354 parallel 284 39GBP 7.28 240 serial 95 39GBP 2.4
In conclusion the best performer value for money is 23HS45-3008D parallel connection. Also is the most powerful at 1000 Hz. As you can see 23HS9430B despite being “the most powerful” comes last.
Wish I was helpful
Contact address at Cazare Pensiunea La Trovanti Horezu
