585,575 active members*
4,016 visitors online*
Results 1 to 2 of 2
    Aug 2006
    17
    Thumbs up How much runout is normal?
    Hi there,
    I removed the D1-4" CamLock chuck from my typical chinese import lathe today and measured the runout on the taper nose and the mating plate. I measured about 0.01mm on both. Is this normal or is there something I can do to improve it?
    Here's the measurement: https://www.youtube.com/watch?v=d02_FN2AsXM
    Cheers,
    Alex
    Do it by the book.. but be the author!
    Aug 2006
    17
    Re: How much runout is normal?
    Hi guys,
    I've tightened the preload on the main bearings as per this picture:
    Attachment 259810
    The runout on the plate is now almost not measurable, however the runout on the taper nose is unchanged. See video:
    https://www.youtube.com/watch?v=Qiy7uboBSg0
    Any ideas where to from here?
  1. What is Runout
    By ToyMaker in forum FAQ of DIY CNC Machine Building
    Last Post: 07-12-2013, 07:51 PM
  2. HRT 210 turntable runout
    By metalmansteve in forum Haas Mills
    Last Post: 03-08-2010, 04:33 AM
  3. 1/8 Collet runout - or ruter runout
    By slavkok in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-04-2010, 02:24 PM
  4. runout
    By gregoryblaine in forum Uncategorised MetalWorking Machines
    Last Post: 08-12-2009, 05:55 AM
  5. Runout
    By grantmi1 in forum Hard / High Speed Machining
    Last Post: 06-12-2003, 09:22 PM
