585,667 active members*
3,983 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > How can I get an email notification of job complete?
    Apr 2006
    40
    I am was wondering how I can modify a script so that I can get email notification that my job is complete. I am using the mach3 2010 screenset with latest Mach3.
    Thanks,
    CP
    Mar 2006
    113
    This is a text messaging that works with Verizon (vtext). I would assume you can play with it to get it to work via email. Where is says [email protected] put in your email. Where it says xxxxxxxxxx put in your phone number. Where it says xxxxxx put in your email user ID and Password.
    'M3030 Macro
    Message " MACHINE #549, Process COMPLETED Call Home"
    Const cdoSendUsingPickup = 1 'Send message using the local SMTP service pickup directory.
    Const cdoSendUsingPort = 2 'Send the message using the network (SMTP over the network).
    Const cdoAnonymous = 0 'Do not authenticate
    Const cdoBasic = 1 'basic (clear-text) authentication
    Const cdoNTLM = 2 'NTLM
    Set objMessage = CreateObject("CDO.Message")
    objMessage.Subject = "Machine Alert"
    objMessage.From = """Machine #549"" "
    objMessage.To = "[email protected]"
    objMessage.TextBody = "Machine #549 Process Completed.." & vbCRLF & "Thank You(;-)"
    '==This section provides the configuration information for the remote SMTP server.
    objMessage.Configuration.Fields.Item _
    ("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
    'Name or IP of Remote SMTP Server
    ("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "[email protected]"
    'Type of authentication, NONE, Basic (Base64 encoded), NTLM
    ("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = cdoBasic
    'Your UserID on the SMTP server
    ("http://schemas.microsoft.com/cdo/configuration/sendusername") = "xxxxxxxx"
    'Your password on the SMTP server
    ("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "xxxxxxxx"
    'Server port (typically 25)
    ("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
    'Use SSL for the connection (False or True)
    ("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = False
    'Connection Timeout in seconds (the maximum time CDO will try to establish a connection to the SMTP server)
    ("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 60
    objMessage.Configuration.Fields.Update
    '==End remote SMTP server configuration section==
    objMessage.Send
    End
    Apr 2006
    40
    Thanks, that worked great.
