Hengfei woodworking cnc router 6 spindles and 6 rotary clamps
Attachment 233770
Working size |
2000*1300*300mm |
Frame |
Heavy welding steel structure,Steel gantry |
Control system |
NC STUDIO CONTROL SYSTEM PCIMC-7A |
Spindle power |
Italian1.5KW HSD Spindle----6pcs |
Servo motors and drivers |
Stepper motor |
Inverter |
Taiwan delta inverter |
X Y structure |
Straight rack and pinion ,Hiwin linear rails |
Z structure |
Germany ball screw and Hiwin linear rails |
X Y Z Traveling Positioning Accuracy |
±0.02mm/300 |
X Y Z Traveling Repositioning Accuracy |
0.03mm |
Max Rapid Travel Speed |
30000mm/min |
Max Working Speed |
25000mm/min |
Working voltage |
AC380V,3PH,60/50HZ |
Calibration system |
Tool sensor |
Command code |
G-code |
collet |
ER30 |
Software |
Artcam software,powermill software |
Special design for cylinder works,6 spindles along with 6 rotary clamps,
We can also put the falt worktable for your normal door works.
Skype:hengfeicnc_laser
professional sales and engineer on CNC router,laser engraving and cutting machines,have been to Europ,USA,South afica,etc for machine training.skype:hengfeicnc_laser.
