Hello,
I have a 6040z s80 and the spindle went out. I ordered it with the 110v 1.5kw spindle . I purchased a replacement but it is 220v 1.5w.
The vfd is the one that came with the control box. It is labeled as a nowforever model d100s1r5b input is 1ph ac110v 50/60hz output 15.0A. The new spindle is from a ugracnc and is a 1.5 kw 220V 3 Phase (Inverter Output Voltage). Is there any chance I can use my current vfd? Ive had no issues with it.
Thank you all for any help you may offer.
