I drill a lot of 5/16" holes on .058" walled aluminum tubing (6061-T6, 6063-T832, and 6463) - for tubing buttons/telescoping tubing, and thus far have been using the cheap Ryobi drill press from Home Depot (max 3500 rpm). It gets the job done, but the holes are not perfectly round and it takes quite a bit of reaming, deburring, and honing to get everything nice. If I were to use a different machine would the holes be nicer/cleaner and require less finishing work? I was wondering if a more powerful drill press or a milling machine, etc might produce better results, and if so what kind of specs should I be looking at. Thanks!
