Originally Posted by
MetalCarpenter
The center of the radius is the center of the pipe.if the top is z0 and your at z-1.875, the center of the arc in z is -2.9375 below where your tool is so k-2.9375 should be correct.arcing from y-3.25 to y3.25, the center would be at y 0 which is 3.25 positive from where your tool is at.as far as g2 g3, when u change the plane,what it does is change the "drilling axis" so g2/g3 would be interpreted looking from the drilling axis.g19 makes the machine interpret the arcs in yz axis so x is drilling axis.looking from x positive to x0 a g2 would arc up and from y neg to y pos.a g3 should arc up from y pos to y neg.let me know if it works
