585,931 active members*
5,100 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Helical Milling on VR-40
    May 2009
    1
    Trying to do some Helical Milling on an Okuma VR-40 with OSP500M-G control. On the line of my program that contains G17 G02.... I get alarm 452, which according to the alarm book it could be that my control does not have helical milling abilities. Is this a simple paramter setting in the control? If so does any one know which parameter and what it should be set to.
    Ok so I went and tried a couple of things and the program will run until I give it a z move, meaning it will do the circular interpolation all day long but soon as I add a Z move it alarms out. So I am either programming the Z move incorrectly or the control won't handle the helical interpolation. So this beggs the question again, is this a simple parameter thing or am I out of Luck??!!
    Thanks,
    Dec 2008
    79
    no you can't , we got the exact same machine
    the control tont support helical milling (XYZ moves in G2 or G3 mode), you got to output small G01 on a CAM program (like mastercam)
    Oct 2009
    114
    Yes As Goldorak said, helical cutting is option for VR-40. Better to get a cam program
  1. Helical milling a slot
    By kevinheez in forum Surfcam
    Last Post: 05-02-2008, 01:14 PM
  2. Helical Bore Milling
    By Ginger_Ninja54 in forum MetalWork Discussion
    Last Post: 01-13-2008, 03:50 PM
  3. Helical Milling
    By binzer in forum GibbsCAM
    Last Post: 03-30-2007, 10:39 PM
  4. Helical milling with HAAS
    By dinger in forum G-Code Programing
    Last Post: 06-19-2006, 07:36 AM
  5. helical milling
    By hogman in forum GibbsCAM
    Last Post: 04-22-2006, 02:15 AM
