I need to tap some holes in some 6061 and it need to get hard anodized. How big should I go with the oversized tap so I don't have any problems?
Why don't your just plug the holes?
B
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
customer wants everything black hardcoat
Aluminum gets etched (cleaned) before anodizing, which removes some material. The anodizing adds about the same amount that was etched away. One H size on the larger should be plenty. There is a very informative post at this site on this matter including stress distortion problems from anodizing.
Look up mil-a-8625 for the spec. Not sure if it has the thickness there but the anodize usually is .002" thick, where .001" of that eats into the material. So it is usually .001" off the original surface.
