585,604 active members*
3,507 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > HAAS TL1 Tool Room Lathe Problem
    Mar 2014
    2
    New lathe programmer, When I write a program with more than one tool used , the lathe stops at each tool change and I have to push the cycle start button to activate the next part of the program.
    I want to use 2 or 3 different tools , push the cycle start button 1 time, and have the program run completely with all the tool changes. The lathe has a 4 position indexing turret.
    Is there a M function I am leaving out or a paramater I need to change?
    screasy
    Oct 2011
    106
    Re: HAAS TL1 Tool Room Lathe Problem
    It seems there is probably an M00 line in the code once your tool has returned home. This is program stop. You can either take it out, change it to an M01 which is optional stop then you can use the op stop button to turn it on or off as you need. Or you can put a backslash in front of the M00 on the same line and hit the block delete button to ignore it.
    Mar 2014
    2
    I found it, the setting 42 was turned on, I just turned it off and everything works great.
    Thanks,
  1. HAAS tool room mill ignores G52
    By DingoHammer in forum Haas Mills
    Last Post: 05-16-2012, 02:18 PM
  2. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  3. Tool Room Lathe Chucker (HPCL)
    By HAILINHAAS in forum Haas Lathes
    Last Post: 12-22-2008, 06:38 PM
  4. Tool Room Lathe - full enclosure or not?
    By flashno in forum Haas Lathes
    Last Post: 10-16-2008, 08:38 PM
