585,741 active members*
5,059 visitors online*
Results 1 to 5 of 5
    Feb 2014
    5
    Haas mini mill 2006 board
Name:	PCB Haas mini mill 2006.jpg
ID:	254750Hello all Cnc friends. Does anybody know how much is for this board..? Haas pcb main pro cf 1/16 mb. Board where is the battery and memory. 1mb ram Loose all the data low battery. Or any know if it's possible install the original software. I made my backup. 3 files. PAR. OPT SET.. Haas mini mill 2006. Software version 14.02d
    Aug 2010
    579
    Haas Factory Support
    Generally, you need to call your local HFO (dealer) to get pricing for your region. If it's available in your region, you can use haasparts.com and find almost every part for any machine. Just looking at a generic mill with that software version, you need 93-32-4412B, which is $3495 in the US. Please verify with your serial number before proceeding.
    Thanks,
    Ken Foulks
    Feb 2010
    1184
    Re: Haas mini mill 2006 board
    Quote Originally Posted by CNCFanMx View Post
    What exactly is the problem with this board and what exactly are you looking to do? Your post is not quite clear.
    Mar 2010
    1852
    If you lost the parameters because of a battery failure then just replacing the board will not help. You will still need the software reinstalled. Just have the battery replaced and the parameters etc loaded again, no need for a new board.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Nov 2006
    36
    I replaced the processor board on my '06 TM2 it cost ~$3500
  1. New Haas Mini mill
    By Ridehd in forum Haas Mills
    Last Post: 10-20-2013, 06:07 AM
  2. Haas Mini Mill
    By Evolve44 in forum Want To Buy...Need help!
    Last Post: 05-16-2013, 05:37 AM
  3. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
  4. haas mini mill
    By johnmckeown in forum Haas Mills
    Last Post: 02-19-2009, 05:26 PM
  5. FS: 2006 Haas TM-1 Toolroom Mill
    By Edster in forum Haas Mills
    Last Post: 01-22-2007, 04:20 PM
