585,906 active members*
3,752 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Haas Lathe Toolsetter Calibration
Results 1 to 2 of 2
    Oct 2010
    14
    After having to re-calibrate the toolsetter on our 2014 ST-30 a few times now using both the 2012 and 2014 manual, I got a quick, simple and accurate method from a Technician and wanted to share it with those that have a Haas Lathe with the probe/toolsetter and find yourself in need. Yes, you can touch off on the part and comp your tools, but some of us run many small jobs and the toolsetter makes life easier when making repeated tool change overs.
    The .PDF is attached here so anyone can grab it.
    Feb 2016
    1
    Do you still have this PDF? I don't see it on here.
  1. Toolsetter
    By nitewatchman in forum Tormach Personal CNC Mill
    Last Post: 04-28-2013, 01:25 AM
  2. Haas Home Made Automatic CNC toolsetter
    By segama in forum Haas Mills
    Last Post: 02-08-2013, 08:15 PM
  3. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  4. Hardinge threading lathe calibration
    By ccarlsen in forum Hardinge Lathes
    Last Post: 02-22-2012, 11:27 AM
  5. Fanuc OT lathe probe calibration
    By Ztiggi in forum Fanuc
    Last Post: 03-14-2008, 07:36 AM
