585,589 active members*
3,668 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > H 400 Ex 03 ATC Machine Alarm
Results 1 to 7 of 7
    Jul 2014
    10
    Anyone run acrossed this,thinking it's an electrical overload issue?
    Dec 2006
    9
    Quote Originally Posted by Ratdog View Post
    Did it happen during the tool Change?
    Jul 2014
    10
    Re: H 400 Ex 03 ATC Machine Alarm
    Yes it did , the arm is in position to pull the tools from the spindle and the pot. Doesn't do it every time.
    Apr 2015
    8
    Did you get this issue resolved? I am having similar trouble.
    Dec 2009
    539
    Quote Originally Posted by Multivarinate View Post
    Check the ATC door sensor on the actuator. That will give you an EX3.
    let me know - if its not that ill let you know what else it could be
    John
    Jul 2014
    10
    The photo eye that shoots across the magazine, showing a tool in place, wasn't switching.
    Apr 2015
    8
    Quote Originally Posted by shas595 View Post
    John
    The door sensor seems to be working. After talking to Kitumura, they say all the sensors seem to working, and the computer is send the signal to the changer, so it is something electrical or mechanical. I can put in diagnostics mode, set the switch to tool changer and push exe. I can hear a relay trip, and it seems to release the brake on the high speed arm so that. I can (very carefully) move the high speed arm by pushing on it with a stick. Doesn't seem to move on its own though. The rest of the system seems to work for pulling or returning a tool from the mag. Also can't get the chain to turn (100 tool magazine). I might also add that I'm completely new to this machine. Although it has a FANUC 15m, and I'm relatively familiar with an 11T.
  1. MIYANO BND 34S MACHINE ALARM NOT
    By ARSHAD AMIN AWA in forum MetalWork Discussion
    Last Post: 05-15-2018, 02:37 PM
  2. Not able to use machine with APC battery alarm
    By DanielBamek in forum Fanuc
    Last Post: 06-23-2015, 07:34 PM
  3. Machine Alarm 1014
    By chatree_w in forum Fanuc
    Last Post: 09-30-2011, 12:24 PM
  4. Fanuc OT Machine Alarm
    By JerryH in forum Fanuc
    Last Post: 12-23-2008, 03:25 PM
  5. machine fuse alarm!!!
    By pacnc in forum Fanuc
    Last Post: 04-30-2008, 11:28 PM
