The advantages of cnc metal laser cutter:
1,Imported linear guiding system 25mm, with strong carrying capacity, stable running, high precision, and longlife.
2,Z-axis adopt imported ballscrew, equip with standard lubricating oil system, which ensure the machine last longer.
3,Selecting hih-power water-cooled motor and high-performance frequency converter, make machine with good performance, big torque, high efficiency.
4,Softwar with best compacity compatible with Type3/Artcam/CAXA/UG/Pro- E/Mastercam/Artgrave,etc.
samples:
http://www.alibaba.com/product-detai...015029381.html
For more information,pls remember following info:Skype: Angela Jinan
Contact: Ms. Angela
msn: [email protected]
Technology Parameter
Specification X,Y axis working area 1,300*2,500mm Z axis working area <200mm Table size 1,450mm*2,920mm Max. speed 0-30,000mm/min Max. Working speed 0-20,000mm/min Working delicacy 0.02mm Reposition accuracy 0.05mm Max. Feeding height 200mm Command G code *.u00 *.mmg *.plt*.nc Software Type3 ,Artcut,Artcam,Ncstudio software. Max. power consumption 5.5kw Work type stepper(option: servo) Spindle speed 24,000rpm Memory 32M Working voltage AC 220V/380V,50/60Hz Manner of receiving data USB or PCI Running circumstance temperature 0-45 degree Relative humidity 30%-75% Weight 1000kg
