585,749 active members*
3,825 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Getting a Hurco KM-3P to talk to a laptop
Results 1 to 9 of 9
    Mar 2015
    4
    I have bought an old Hurco KM-3P mill off GovDeals and looking for some way for it to talk to a laptop so I can enter G-code into it. The parts I'm going to make are very simple, all I need is some way to type in the commands,
    Jun 2009
    195
    Re: Getting a Hurco KM-3P to talk to a laptop
    I forget if it has a serial port if so look up how to make the cable for the machine and grab some dnc software . you can also make a text file with your code and save it as .hnc then save to a floppy disk .
    there is a ton of info out and the layout of the menu system has not changed much over the years . I have run one of them and have run the winmax controllers .
    tony
    Feb 2006
    174
    What you may need is a Hurco Manual called:
    Conventional NC Executive for Hurco Ultimax Control
    There will be 3 connections on the back of your machine.
    They are military style and you need to make a cable from military to serial
    in order to talk to the PC.. I don't know much about PC's , and the one I use to use was a Win 95 PC, so it had a serial port
    My cable had only 3 wires for serial communication
    The top military port ( #1 )is a output port only
    The next lower port (#2) is for output and input ( ! )
    the lower port is for forth axis communication
    My baud rate was 9600 and the handshake was 7 data bits,one stop bit and even parity
    It is in ASCII Format
    the NC file first character must be a " %" sign and the last character must be a "E" to close the file
    my notes say I talked to Steve Artz at Hurco and he sent me the info
    For the cable I have:
    Hurco port 2 to a 9 pin PC plug
    D9 pin 2 TXD transmit data to > PC pin 2 RXD
    D9 pin 6 RXD, receive data < from PC pin 3 TXD
    D9 pin 7 DTR data terminal ready > PC pin 4 DTR
    D9 3 Signal ground---------------------PC 5 connect to shield at machine only !
    I also have this
    #3 to #2
    #2 to #3
    #7 to #8
    #8 to #7
    #5 for ground shield
    This was 10 years ago and i don't recall which cable was used as I had to play with it
    I know that Predator makes a cable(Grizzly) for the Hurco DNC work
    Predator Hardware - Wired or wireless rugged MDC, DNC or CNC Networking Hubs, RS232 hardware or Predator Grizzly cables
    Rich
    Feb 2006
    174
    Jun 2009
    195
    That pin configuration sounds right .I made a cable for work you can get db-9 ends at RadioShack before they go under ! If you make your own I would recommend soidering the wires to the pins !
    Tony
    Mar 2015
    4
    Thanks to everyone, my biggest problem is that I am very new to this kind of stuff. The owners manual say's it is was made in1986, but does not say if it was a ULTIMAX, where can I find that information
    Jun 2009
    195
    Grab a manual from hurco the programming concept is the same over the years and will help
    Tony
    Mar 2015
    4
    I have found out that it might be a BX control, does that matter?
    Feb 2006
    174
    Quote Originally Posted by gdavis15 View Post
    Should be OK !
    The BX Control had .0001 capability.
    I found out that my comment on the top two ports may not be accurate
    Some Hurco's had in/out on the top and not just printer out as I said...so be aware
    Rich
  1. Replies: 0
    Last Post: 02-12-2015, 10:46 AM
  2. Replies: 2
    Last Post: 12-11-2014, 03:46 PM
  3. Replies: 0
    Last Post: 01-30-2014, 08:06 AM
  4. How to connect Hurco to PC/Laptop
    By J.B.D. in forum HURCO
    Last Post: 08-23-2012, 05:00 PM
  5. Let's talk some about Cam....?
    By pete from TN in forum Benchtop Machines
    Last Post: 09-13-2010, 02:39 AM
