The A axis only moves into single direction.
I've attached my settings bellow, when i connect the same motor to any other axis X, Y ,Z it does move into both dirrections as it should.
I've never used this A axis before on this controller so i'm not sure if it ever worked.
I have 2 keys set to move the A axis, "z" keyboard key and "x" keyboard key, and when i press any of them the voltage on pins 6-7, 8-9 does change and of course the're set to move the axis into different directions.
I also replaced pins 8-9 with 2-3 from X axis and vice versus, the issue still reproduces
I can't figure out what's wrong, is it the controller or i have some wrong settings
Please help, thanks in advance
