585,781 active members*
4,025 visitors online*
Results 1 to 2 of 2
    Jun 2014
    4
    g code problem
    im cutting 15mm fibre glass my toolpath is set to 15.4 deep but when i cut on the machine for some reason its goin to 48mm deep !!! just put a hole through my deck and snapped a tool and colet. any ideas on why its doing this ? its only on 1 group of tool paths thats the problem.
    Jan 2005
    15362
    Re: g code problem
    domokun
    Sounds like you never set the Z axes offset G43 do you have a G43 Z.1 H3 in your program H3 is your tool number, this is were you tool offset is set in you tool table in the control
    T3 M6 (Tool #)
    G54 (work offset)
    S24000M3
    G90 G0 X0 Y0 (Start Position)
    G43Z.1H3 (Z axes Tool offset)
    Mactec54
  1. g-code problem
    By accuratesports in forum Dolphin CAD/CAM
    Last Post: 12-12-2013, 01:25 AM
  2. code problem please help
    By fanouxri in forum Okuma
    Last Post: 11-13-2013, 03:24 AM
  3. G Code Problem
    By Dr Bob in forum Uncategorised MetalWorking Machines
    Last Post: 12-03-2009, 08:39 PM
  4. Problem with code G0
    By harm190 in forum Mach Mill
    Last Post: 03-17-2008, 09:13 AM
  5. g code problem
    By SIMONSIGNS in forum Uncategorised CAM Discussion
    Last Post: 03-22-2007, 04:46 PM
