Tried posting earlier, but browser crashed after typing and uploading all the pics.
So, loaded up around 6:30 this morning and arrived at machine location about 7. Got Bobcat unloaded and trailer staged in back alley of welding shop.
Attachment 256122
So the back rollup door hadn't been opened in over 10 years. While I prepped the mill, drained the oil, made sure the knee, table, and ram were secure and flipped the head, the shop employees couldn't get the door open. After messing with it for awhile, my buddy pushed them out of the way to have a look, starts flinging pipes and other metal stock out of the way and delcares, "It's got a PADLOCK on it."
So, being a good welding shop, with many ways of making metal dissappear, the lock vanished and up went the door. We had to drag the mill a few feet away from the door, because it had been set on and improvised steel / plywood platform that made the ramp for the backdoor into a level usable floor space. Next, we spun her around, and SLOWLY drug her accross 1" plywood sheeting out onto level ground.
Attachment 256124
Next came out 2x4's inbetween the ram and forks. A 5,000 lb strap was attached to keep the ram from trying to slide off the forks and we were off to the races.
We loaded the mill from the side of the trailer onto 4x4 dunnage, strapped it down, then drove the Bobcat back on.
Attachment 256126
At this point, my buddies worked on getting the Bobcat secured, and I got to dust off my old C-130 Loadmaster skills. Luckily, I had access to 6 10,000 lbs chains, and 5 10,000 lbs jacks/devices. I had some really good carpet tile squares that would bend where you needed them too, and made a chain bridle around the base of the mill. Then I 4-Pointed it, with another dead-man back to the Bobcat, and a set of chains plus 5k strap over the knee.
Attachment 256128
Upon arriving home 11.5 miles later, we reversed what we had done earlier and BAM! There she is.
(just ran into picture posting limitations, and CNCZon doesn't want to link to Photobucket).
Attachment 256130
In total, took maybe 2 hours from gaining access to the machine and it sitting in my garage.
Attachment 256132
Now onto crud, goo, and nastiness removal.
Here's a shot of the mainboard / computer side cabinet in the light of day. I wonder which of these components will be work saving?
Attachment 256134
I don't remember these being in the bottom of the cabinet before the move, but maybe they have / had something to do with the NC control not working?
Attachment 256136
On the mainboard side mounted on the door, does anyone have a clue what the brown breadboard is / was for? Add-on, upgrade, by-pass?
Attachment 256138
I got to finally access the middle, smaller cabinet in the back of the pedestal. What is a Nintendo cartridge slot doing in the back of my mill!?
Attachment 256140
Oh, more chips just hanging out.
Attachment 256142
I find it somewhat strange that on the Power and Driver side cabinet, it is pretty clean and immaculate. On the computer side, the air cooling fans are frozen, and everything has a residue on it. Next stop, do some "light" surface cleaning starting with the head.
Just some before and after of the head. Lots of goo and oxidized grease, oil, chips everywhere and in everything.
Attachment 256144
Attachment 256146
Attachment 256148
The serial of the table and head match.
Attachment 256150
Does anyone have any info on researching the pedigree of serial numbers?
More pics and stuff to follow as the Tree gets electronics pruned, and internals watered.
-Kit
