Hi all - relatively new Patriot CNC owner here. I was fighting an oil leak coming from the oil seal around the retainer for the lathe spindle. When I disassembled the spindle and pressed off the bearing to get to retainer off, I saw the worn/damaged felt seal. Replacing that with a new piece of felt wasn't working for me - couldn't get the right size felt, and trying to fashion a new piece of the proper thickness/length just wasn't working.
Instead, I found it pretty easy to machine the retainer to accept an automotive-style oil seal. A quick look through the Timken catalog found a seal with the proper dimensions. The 47X62X8 seal (also made by Precision Automotive) worked nicely. Timken p/n 710320 would also work. I simply machined the retainer plate to match the OD of this seal (62mm, or 2.440"), and lightly polished the journal on the spindle itself (journal diameter was 1.855" - seal ID was 1.850". Taking off a couple of thousandths via polishing was all that was required). Fortunately, I had another small lathe to do this work (who says Harbor Freight isn't good for anything?). I suppose you could also mill this out - I just didn't have the guts to try that
Now, finally - no more oil leak from the lathe spindle.
