I've been around on the zone for several years. Don't have the time to post very often. Call this a simple introduction.
Started with a converted x2 some years back. Learned the ins and outs of cheap drivers, why the G540 is a value, etc. Jumped from there into a Tree VMC1060 after a year plus. The Tree has been a great tool for the maybe 2 days a month I've had time to run it over the past few years. Life changes required me to move from my space of 25 years into something much, much smaller. So the Tree had to go. So did the Takisawa/Webb lathe - miss that so much. G0752 inbound as replacement (no current plans to convert the lathe).
I have often researched and considered a Tormach or Novakon personal mill. I realize in many ways these are a step back from something like the Tree (had it working brilliantly via CamBam and CodeShark). However, the truth is I generally machine aluminum and don't need the massive travels, rapids or spindle HP of that beefy VMC. I've been watching for a good deal on a used PCNC for some time - one finally popped up a couple months ago. Series III with ATC, PDB, 4th axis and more tool holders than I need for the moment. Original owner took quite good care of the machine, built a 3/4 enclosure for it, and sold it for what I believe is a solid and fair deal.
I retrieved it a few weeks back. She's wired and running now. Had to buck up the 208 at the new place and ran a dedicated circuit for the mill, another for the compressor, and a third for the computer since I was at it anyway. Shop isn't quite setup yet and won't be for several more weeks. Stuffing 7,000+ sq ft of stuff into 1,500 is difficult at best. Photo attached is the *machine shop corner* and has a lot to be done still. Lighting, organization, finish out a full enclosure on the mill, etc. Small space = higher level of OCD necessary.
So - I'm here - will try to post useful information as I discover it. Initial cuts and tests/tramming/leveling are promising. Very capable machine from what I can see thus far.
Thanks to all that contribute to this forum and in general on the web. Makes this machining *hobby* that much more enjoyable.
WW
(Goofy tunable chamber muffler concept I knocked out one day on the Tree - still a work in progress - also pictured below)
