I am trying to make a program that runs on a makino with macro b. It has a harddrive where the program from
the cnc programmers go. They have a main program in memory that runs that program on hardrive thru 1 to 8 positions.
No biggie, common main program that cuts electrodes in 3r fixtures.
m198 is the code used to run the file off the harddrive. thats why im here, if it was m98 i could test it on one of the macro sims.
But using m198 i dont know if the variables pass to the hardrive.
My problem is debug time, the machines are busy all the time. I can get a little time here and there, so im trying to cut down
on my debug time. (I work in another area in the shop)
I cant believe this program doesnt exist easily to find?
So here's the jest of it, the program runs from memory, program O0010.
It calls up tool 1 from the hardrive program made in the cam, O0020 and runs that tool thru all the positions.
then, it grabs the next tool and runs it thru all the positions, etc... till all tools are done.
10 toolchanges as opposed to 80.
Heat control since each position isnt running tools from 2000rpm to 30000 rpm, and then going to the next position. it stays at 2000 till
all positions are done, then goes to the next tool at a different rpm.
The machine can be warmed up with dwells before the finish tools run.
consistancy is what im after.
here's the code, please dont be afraid to insult me. Im on version 3. Id love to go to version 4!
See a better way, please let me know.
main in memory ********
O0010
#100 = 10 ; ENTER PROGRAM NUMBER FROM SETUP SHEET
#101 = 8 ; ENTER NUMBER OF POSITIONS 1-8
#102 = 1 ; ENTER STARTING TOOL FROM SETUP SHEET
#103 = 10 ; ENTER ENDING TOOL FROM SETUP SHEET
N40
IF [#102 GT 8] GOTO 50
G00 G54.#101 X0. Y0.
M198 P#100
#101= #101 - 1
#102=#102 + 1
GOTO 40
N50
#3000=5(YOU TYPED IN TOO MANY POSITIONS);
sub on hardrive posted from cam system (ug)************
O0020 ;
IF [#102 > #103] GOTO 100
GOTO #102
N1 T1
M99
N2 T2
M99
N3 T3
M99
N100
G91G28Z0
M20
Please help me make this better and debug free....thanks.
