585,949 active members*
4,265 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC controllers ethernet compatible?
Results 1 to 6 of 6
    We have FANUC 0M & 3M controllers. The shop is trying to locate the documentation but does anyone know if these controllers are ethernet compatible? I'm told that if the are, I don't need to use DNC software to load programs. Thanks in advance!
    Skip
    Apr 2009
    1379
    Re: FANUC controllers ethernet compatible?
    As far as I know, the 0i-c controls and newer had an ethernet option.
    Many Thanks!
    Feb 2009
    6028
    For sure no Ethernet on those old controls. Data servers came about in the mid 90's that had some form of Ethernet. Those were usually a very pricey option on 16M controls.
    Beacause you mentioned 16M controls (newer?), the 0M and 3M are much older? If ours aren't ethernet compatible, I will find a better DNC that can load from a laptop.
    Apr 2009
    1379
    The 3 and 6 series date from the late '70s, the 0,10,11,12,15 series from ~1986.The 15b,16a,18a etc started in ~1991.
  1. Post compatible fanuc 0i-MB
    By mcamdalpla in forum Post Processors for MC
    Last Post: 06-14-2013, 08:37 PM
  2. Fanuc encoders compatible with PICO
    By wyobmf in forum Servo Motors / Drives
    Last Post: 03-22-2010, 06:18 PM
  3. Ethernet/PCI Motion Controllers
    By 2_many_hobbies in forum Stepper Motors / Drives
    Last Post: 11-12-2009, 04:50 PM
  4. Replies: 2
    Last Post: 02-04-2009, 11:47 PM
