585,927 active members*
3,433 visitors online*
Results 1 to 14 of 14
    Jun 2003
    241
    Fanuc 6T-B type II g71
    Can the 6T control do Type II roughing? If it can, does it require a hardware upgrade or is it just a parameter change? I'd like to have the type II roughing but if it requires a hardware upgrade it may be too expensive for this old machine.
    Aug 2011
    2517
    Re: Fanuc 6T-B type II g71
    Type II is enabled in the program by putting a X and Z on the first line after the G71 line.
    i.e.....
    G0 X10.0 Z1.0
    G71 P10 Q11 U0.01 W0.005 D2000 F0.014
    N10 G0 X1.0 Z0.99
    N11 X10.0
    If you get an error then your machine doesn't have the option parameter set.
    Jun 2003
    241
    I found that out a while back when trying to rough an undercut area, interesting if you're not expecting what it will do with a 3/8 inch deep undercut. Luckily it was in aluminum.
    The machine is old and I don't want to spend a whole lot on it, that's why I wanted to know if it requires a hardware upgrade or just a parameter change that will activate the function.
    Aug 2011
    2517
    it's just a parameter change...... check your PMs.....
    May 2014
    36
    Would a 6T-A have this option ?
    Aug 2011
    2517
    yes I think so. just try it. if it works it has it. if not then no.. 50-50 chance..... ;-)
    Jun 2003
    241
    It worked on my 6T-B control, thanks!
    May 2014
    36
    Ok im still fairly new at programming but im going to give it a bash just now and see if it works .
    From what ive read its a better option to use type 2 anyway .
    Aug 2011
    2517
    here's a sample. if you dont get an alarm your machine has it. if you get the alarm it *can* have it but its an option (a parameter change is required that's all)
    G0 X10.0 Z10.0
    G71 P10 Q11 U0.1 W0.01 D2000 F0.01
    N10 G0 X9.0 Z9.99 (<-- X and Z on this line activates Type II cycles)
    G1 X8.0 Z-1.0 F0.01 (feeding smaller in X here is not allowed with Type I cycles)
    N11 X10.0
    Type II cycles normally blend out the cuts instead of leaving steps. It could depend on the machine tool builder and how they implemented it.
    May 2014
    36
    i get an 065 alarm so i guess i dont have the option .
    Jun 2003
    241
    The issue I had with not having type II roughing is that when it roughs it will only do uni-directional feeds as in only x- or x+ and only z- or z+ BUT when it does the semi-finishing pass it follows the profile as programmed. In my case it meant a 3/8 inch deep semi-finish pass in an undercut.
    May 2014
    36
    Yes that is a problem.
    I have to use single line programming for any cutouts/undercuts that i need to do.
    Its a pain to program and with the small memory sometimes i need to put the parts back for a second program.
    Aug 2011
    2517
    check your PMs and your problem could be solved....
    May 2014
    36
    Ive replied .
  1. Fanuc T6 G71 type 2 G-code troubles
    By Snowie in forum Fanuc
    Last Post: 12-16-2011, 01:03 PM
  2. Can't run Type II program on Fanuc 21i-T
    By SlowRiderr in forum Fanuc
    Last Post: 11-20-2008, 01:49 PM
  3. Fanuc 0i-MC and ARM type toolchanger
    By ddanutz in forum Fanuc
    Last Post: 08-27-2007, 10:57 PM
  4. gettys fanuc type 10 motor
    By najnielkp in forum Fanuc
    Last Post: 05-07-2006, 02:47 PM
  5. New Amps for Fanuc Type 10 DC Motor
    By aus-newb in forum Fanuc
    Last Post: 11-24-2005, 12:03 AM
