585,948 active members*
3,817 visitors online*
Results 1 to 5 of 5
    Jul 2006
    9
    Fanuc 6M servo alarm
    Hi, All
    I have an urgent problem with a servo alarm. After shutting down normally last night, trying to power-up this morning has produced a stubborn alarm #401. Looking it up in the book ,it says something like the velocity control for one or more axis has turned off.
    Any way I can get it up and running, or is this a service call?
    Thanks in advance for any help at all!
    Dec 2003
    24221
    Try the resets on the drives, check the fuses and the flag fuses.
    Al.
    Albert E.
    Dec 2006
    1
    I was just having a similar problem on my 15-M.
    I could get is started after about 6 tries.
    Had to replace the Z board.
    Do you have any alarm Leds on the servo drive?
    Check for 100vac between terinals 3 and 4 on each servo drive
    Dec 2006
    5
    Hi guys, sorry for my bad English but I' m from Italy...
    If you don't have red Light led On (Alarm) and if you have the 100Vac on pin 3-4 replace the MCC on POwer PCB of Servo Alarm 401 means problem on axes X or Z due to from the VRDY Signal. Usually the problem is due to the bad contact of the signal VRDY trought the MCC.
    Googd luck and tell me something.
    Bye Andrea.
