585,997 active members*
4,911 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Oct 2014
    25
    Fanuc 6 problem
    Can anyone help me with the fanuc 6m??
    I have this errors
    600
    603
    607
    This is appear on the CRT after I unplug the 6 wire connector that located on the power unit
    So before I did that there was not anything appear on the CRT nothing powered up ..I don't know what I should be doing with these errors
    Replace PCB master or pc model-b or mdi and crt or connection unit. ...Please someone help me
    Dec 2012
    395
    Re: Fanuc 6 problem
    I can't help you but I can give you the Fanuc 6 alarm-list.
    Regards,
    Heavy_Metal.
    Oct 2014
    25
    Re: Fanuc 6 problem
    Thank you my sir Heavy_Metal .....I have the manual , maintenance , alarm list ... but I don't sure what I should be doing with these alarms (600 603 607) ....
    600
    Data transferring error took place in the connection unit or in PC-model B
    603
    The correspondence between NC and PC is incorrect or interrupted. Change power sequence control PCB or master PCB
    607
    Data transferring error took place in Fanuc MDI & CRT
    Overheat alarm
    ... Please help me
    Oct 2014
    137
    Re: Fanuc 6 problem
    Tell please me, what type PC-B or PC-G is used on your Fs6M?
    Oct 2014
    25
    Re: Fanuc 6 problem
    Dear sir,
    It's Fanuc 6M-B
    PC-B
    Oct 2014
    137
    Re: Fanuc 6 problem
    Your three errors can be by following reasons:
    - not set paramettr N003 bit #7;
    - is bad pc-b A20B-0008-0440 system or Ladder ROMs;
    - not connect or bad serial I/O cable (DIO to MB);
    - is bad pc-b A20B-0008-0440 PCB.
    Necessary to check all this.
    Oct 2014
    25
    Re: Fanuc 6 problem
    Dear sir ,
    I did checking hardware for PC model- B, nothing was wrong , so how I can do checking software for it
    Feb 2011
    640
    Re: Fanuc 6 problem
    double check you didnt knock a plug loose- the DIO cable goes from master to connection unit1 (if you have stacked IO boards, it then loops to the back one) and from connection unit to MDI keyboard connector, then either a terminator plug, or another loop out to op panel IO (last serial device has to have terminator plug). the rear connection unit (if there) is kinda hard to see- make sure the honda plugs are seated- those are the rectangular ones without screws, just clips...they coulda been dislodged when unplugging other stuff if the cables are bundled/tied...
    Oct 2014
    137
    Re: Fanuc 6 problem
    If software of the PC-B is Ok, that you have possibility to enter the PC parameters.
    Oct 2014
    25
    Re: Fanuc 6 problem
    Yes I can enter the parameters list.. .so
    .how much percentage (probability) that can you give me it to replace the master PCB ??
    Oct 2014
    137
    Re: Fanuc 6 problem
    Main Board you can check so: Set the parameter N003 bit #7 to 0. All your errors must be lost.
    Oct 2014
    25
    Re: Fanuc 6 problem
    Ok, I will check that. ..thanks alot .
    Oct 2014
    25
    Re: Fanuc 6 problem
    Attachment 255296
    I can't switch MDI mode on
    On the other hand, power off lamp is light
    Oct 2014
    137
    Re: Fanuc 6 problem
    For write CNC parameters in Not Ready state you need following:
    - Press button "Emergency Stop";
    - Switch "Parameter Write" on MB to "Enable";
    - Enter selected parameters.
    Oct 2014
    25
    Re: Fanuc 6 problem
    My dear agering
    Does you mean changing 10011000 to 00011000 ?
    Oct 2014
    137
    Re: Fanuc 6 problem
    Yes, it is necessary to change.
    Oct 2014
    25
    Re: Fanuc 6 problem
    Dear agering
    I did all things that u tell me ... I can't change any parameter. ...do u have any idea about that?
    Oct 2014
    137
    Re: Fanuc 6 problem
    It is Necessary to check all connections, cable and power voltages to MDI&Connection Units. If you need Maintenance manual or other information tell please me your e-mail.
    Oct 2014
    25
    Re: Fanuc 6 problem
    Dear agering
    That's my email [email protected]
    I will be thankful and appreciative
    Oct 2014
    25
    Re: Fanuc 6 problem
    fanuc 6m-b problem
    I have centrum 1000 fanuc 6m-b cnc turret punch ..I have problem with it.... alarm message on the CRT display when I power up it ...I think that the ex worker who was working on it changed something (software or hardware) on it ...However I don't have the electrical connection manual ... I think that if I have other machine like it , I will make helpful comparison between those. ...
    Alarm 600
    Alarm 603
    Alarm 607
    Anyone have the same machine can help me
    Any help I would be greatly appreciate. ...
Page 1 of 2 12
  1. fanuc problem
    By beh1978 in forum Fanuc
    Last Post: 12-29-2015, 11:05 PM
  2. Fanuc problem
    By majid in forum Fanuc
    Last Post: 09-07-2012, 05:40 PM
  3. Fanuc 18M oil problem
    By mustafaguler in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2008, 08:35 AM
  4. Fanuc new 0I problem
    By sylvain in forum European Club House
    Last Post: 12-30-2007, 06:17 PM
  5. Fanuc OT problem
    By Skybrake in forum Fanuc
    Last Post: 02-09-2007, 07:04 AM
