Code:
#include "KMotionDef.h"
#define FEEDHOLDBIT 46
#define CYCLESTARTBIT 47
#define ESTOP 26
#define HALTBIT 27
#define RESTARTBIT 28
#define ZEROALLBIT 29
// function prototypes for compiler
int DoPC(int cmd);
int DoPCFloat(int cmd, float f);
int Debounce(int n, int *cnt, int *last, int *lastsolid);
// state variables for switch debouncing
int flast=0,flastsolid=-1,fcount=0;
int clast=0,clastsolid=-1,ccount=0;
int elast=0,elastsolid=-1,ecount=0;
int hlast=0,hlastsolid=-1,hcount=0;
int rlast=0,rlastsolid=-1,rcount=0;
int zlast=0,zlastsolid=-1,zcount=0;
main()
int result;
for (;;) // loop forever
WaitNextTimeSlice();
// Handle FeedHold/Resume
result = Debounce(ReadBit(FEEDHOLDBIT),&fcount,&flast,&flastsolid);
if (result == 1)
if (CS0_StoppingState == 0)
StopCoordinatedMotion();
else
ResumeCoordinatedMotion();
// Handle Cycle Start
result = Debounce(ReadBit(CYCLESTARTBIT),&ccount,&clast,&clastsolid);
if (result == 1)
DoPC(PC_COMM_EXECUTE);
// Handle ESTOP
result = Debounce(ReadBit(ESTOP),&ecount,&elast,&elastsolid);
if (result == 1)
DoPC(PC_COMM_ESTOP);
// Handle HALT
result = Debounce(ReadBit(HALTBIT),&hcount,&hlast,&hlastsolid);
if (result == 1)
DoPC(PC_COMM_HALT);
// Handle RESTART
result = Debounce(ReadBit(RESTARTBIT),&rcount,&rlast,&rlastsolid);
if (result == 1)
DoPC(PC_COMM_RESTART);
// Handle ZERO ALL
result = Debounce(ReadBit(ZEROALLBIT),&zcount,&zlast,&zlastsolid);
if (result == 1)
DoPCFloat(PC_COMM_SET_X,0.0);
DoPCFloat(PC_COMM_SET_Y,0.0);
DoPCFloat(PC_COMM_SET_Z,0.0);
// Put a Float as a parameter and pass the command to the App
int result;
persist.UserData[PC_COMM_PERSIST+1] = *(int*)&f;
return DoPC(cmd);
// Pass a command to the PC and wait for it to handshake
// that it was received by either clearing the command
// or changing it to a negative error code
int DoPC(int cmd)
int result;
persist.UserData[PC_COMM_PERSIST]=cmd;
do
}while (result=persist.UserData[PC_COMM_PERSIST]>0);
printf("Result = %d\n",result);
return result;
// Debounce a bit
// return 1 one time when first debounced high
// return 0 one time when first debounced low
// return -1 otherwise
#define DBTIME 300
int v = -1;
if (n == *last) // same as last time?
if (*cnt == DBTIME-1)
if (n != *lastsolid)
v = *lastsolid = n; // return debounced value
if (*cnt < DBTIME) (*cnt)++;
else
*cnt = 0; // reset count
*last = n;
return v;
Regards
