Hello all.
First of all thanks for everyone's contributions here! You posts have given me endless hours of research and pondering in preparation for my first CNC plasma table build with water table (Occasionally for a home project I would like the option of using a router on it as well).
The time has come to take the plunge so I though I would get a thread started to document/get advise/brainstorm ideas. I plan an building a table that is able to cut/scribe minimum edge to edge of a 4'X4" sheet. I would have liked to build a larger table but I have to fit this into a 20' long shipping container that I purchased for my shop. Still in the planing stages for the details of the design but I have been inspired by dnelso's builds so I'm hoping to build roughly the same design. Although I do not think the budget is going to allow for all the fine details like dnelso has.
I was planning on using a Hypertherm Powermax 45 but last weekend I scored a Hypertherm Powermax 1000 G3 that is in excellent shape for $1200. It has a hand torch that I think I will just convert to a machine torch for now.
I started ordering of parts:
From Automation overstock I ordered:
Ordered 6 AGW25SAZ1C 25mm Bearing Block, 2 Bolt Flanges (they were sold out of 4 bolt) and AG 25 R Rail Sections 2 x 1700mm 1X 1550mm
Z axis I will make myself (Hoping for aprox 6" travel)I have 20mm rods and bearings ordered and a Ballscrew1605-365mm (Φ:16mm Pitch:5mm L:365mm) end machined+ballnut+FK/FF12 end supports
Haven't Nailed down the rack on pinion choice or supplier yet. X+Y axis will have belt driven gear reduction. I keep flip flopping on having it spring loaded to automatically take up backlash or not.
For motors/control I plan on using CandCNC ETHER-CUT MARK IV 620-4...although not sure if I should just get the Dragon cut system?
Guess that's about it for now, just waiting on the postman so I can start on something!
